closing pro_comm_msg.exe
Hi all,
I have been working on J/Link. I am facing with a typical problem while
closing PRO/E.
When I open Pro/E through J/link with having graphics mode, then exiting
the PRO/E application through J/Link also ends pro_comm_msg.exe process.
But, if I do the same with out having graphics mode, pro_comm_msg.exe
process is not being closed.
Can anyone help me out in this regard?
With regards,
V.Amar
    V.Amar,
    I am pretty sure that this is normal behavior and pro_comm_msg.exe will
    stop eventually. I wouldn't worry about it too much. Is it causing
    problems?
    Patrick Williams
    Sr. Application Engineer
    Steelcase Inc.
    pro_comm_msg has a default timeout which I believe to be 300 seconds.
    When you start it, you can specify another timeout. I don't remember the
    syntax to specify the timeout. I believe you can do it on the command
    line or with an environment variable.
    Bob Monat
    Robert A. Monat
    Jerand Technical Services, Inc.
    http://www.jerand.com
    Phone: 317-875-6087 FAX: 317-875-6612 Tollfree(US)888-4JERAND
    Amar Vemanaboyina wrote:
    > Hello Patrick,
    > Thanks for your response.
    > If I run a j/link application with out graphic mode for many a time,
    > some times I am getting connection start error, like XToolKitBusy. To
    > get rid of this, either I will log off my system or restart my pc.
    > Other way around I do is, in TaskManager (of WIDOWS_XP OS), I will end
    > the pro_comm_msg.exe process.
    > Regards,
    > V.Amar
    vemanamar1-VisitorAuthor
    Hello Patrick,
    get rid of this, either I will log off my system or restart my pc. Other
    way around I do is, in TaskManager (of WIDOWS_XP OS), I will end the
    V.Amar
