Apr 19, 2010 9:53 AM UTC
Clothoid curve
Dear all,
I'am trying to construct a clothoid-curve in Pro/e. I have tried "curve from equation" but find this not so userfriendly. Can someone support me with some info on this?
How much is a conic-curve off from a clothoid?
Kind regards,
Dennis Varkevisser
______________________________________________
Dennis Varkevisser
Flexible Engineering Support
<u>www.flexibleengineeringsupport.nl
+31 6 50 68 01 79
</u>
    Apr 19, 2010 10:35 AM UTC
    Dear Dennis,
    The Clothoid curve is defined as a parametric equation using the integral of sine and cosine for its definition. ProEngineer does not have integrals built in to it's equation editor. There are a couple of options that spring to mind, no doubt there are others:
    1) Use an expansion series to define the integral. (see
    Apr 20, 2010 1:52 PM UTC
    I created a UDF some time ago. Maybe that helps.
