Nov 2, 2010 9:12 PM UTC
CoCreate 3.0 PE graphic error !??? Need Help
First I want to excuse me for my bad english, since yesterday CoCreate 3.0 PE doesn´t work. When I open the program it says : create_vp/signal/sigsegv
Probaly anyone knows this error and could help me !? Thank you
Christopher S
    May 1, 2011 1:45 PM UTC
    i have the same problem. have you solved it?
    May 3, 2011 2:54 PM UTC
    seems to be an issue when the system initializes the 3D Viewport.
    Please check the following
    http://communities.ptc.com/community/creo-elements-direct/pe-english?view=all#
    In the Announcement Tab - Number 5 there is a list of tested cards. Is the one listed you are using?
    Creo Elements/Direct Modeling PE has been successfully tested on the most common Nvidia and ATI mobile-, workstation- and consumer-graphic boards together with Windows Vista (see table below).PTC does not guarantee full operability on Intel Media Accelerators or other on-board chipsets.
    And a second check is
    1. On Intel Graphic Media Accelerator the Hardware Acceleration especially in connection with the Enhanced Realism Option is not working reliably. If you are using Creo Elements/Direct Modeling PE 3.0 on a hardware with Intel Graphic Media Accelerator it is recommended to set the following environment variable:
      SDPIXELFORMAT=SOFTWARE
      this will disable the Hardware Acceleration including the Enhanced Realism option.
    2. If the Enhanced Realism Option has been activated in a Modeling PE session it might fail to start in the next session. If you experience such a situation, as a workaround you can remove the users application data folder for Modeling PE: ...\Application Data\CoCreate\CoCreate Modeling Personal Edition3\30.0
      Then restart Creo Elements/Direct Modeling PE 3.0 and remember to deactivate Enhanced Realism before ending the next Modeling PE session.
