Comandline?
Where do I find a list of comands that I can use on the comandline? In general: What is the benefit in using a comandline?
    In general, it is not necessary to know the names of any commands. You can interact with the UI to invoke commands of interest. The command line is normally used by more advanced users. All commands that are available either via the UI or the command line.
