Control O.A.L. Of An Equation Curve
I need to generate an equation curve and be able to set and control the length of the actual curve. Making the equation curve to form the helical “corkscrew” isn’t a problem.I just can’t figure out how to control the “R” value of the curve based on my total length.
Is this doable?
TW
    You can put a point on the curve with the desired length from the correct end, then put a datum thru the point normal to the curve, then trim the curve.
    If the curve is analytical, why not calculate the radius from the required length in a part relation and use it in the curve equation?
    Summary
    Thanks to Terry ! Very helpful info.
    The solution: Create a parameter named "RADIUS" real number with an arbitrary initial value. In the equation for your curve, set the radius equal to the "RADIUS" parameter. Create an analysis feature for the curve and save the length of the curve as a parameter value. Analysis > Measure > Length > Select your curve use the drop-down to create it as a Feature, and name it "curve_length" click on the Feature tab to ensure the parameter is checked to be created, and has the name "LENGTH" Use a Feasibility Study to find the value of R to give a desired curve length: Analysis > Feasibility/Optimization >select the Feasibility radio button under Design Constraints, select "Add", and then select "LENGTH:CURVE_LENGTH" if not already selected, then set the middle box to "=", and select the "Set" button & enter the desired value for the max length of the curve and hit OK, then Cancel from the Design Constraint box. Under Design Variables, select "Add Parameter", and select "RADIUS:whatever_your_part_is_named” enter Min/Max values for the radius value range that will be allowed. You may need to also tighten the default convergence value on the options tab > Preferences > Run tab: then hit Compute:
    Couple things to consider: Make sure that it is possible for Z & T to generate a curve larger than the length set within feasibility. That is also true for the Minimum and Maximum R values. You may need to tweak the min / max R values in feasibility if the curve is coming up short. If everything seems to be working fine but the curve is still slightly short check the convergence setting. If that value is too large it will “clip” the curve and can be shorter than the desired length you entered.
    I didn’t try Frank’s suggestion, I had already use the above process.
    I tried Harald’s suggestion; I was able to trim a sketch curve but not the equation datum curve.
    Thanks – and Stuff.
    Have a great weekend everyone.
    tw
    If I understand this correctly, you want a helical curve of a certain length, and you want both the ends to be coincident to a plane thru the axis of the helix (one turn)? Somewhat like a helical lock washer? You're going to use this curve as a trajectory, I assume? If so, I have an easier solution for you. Shoot me an e-mail.
    Frank
    In Reply to Tracy Willis:
    Summary
    Thanks – and Stuff.
    tw
    Anyways, I modeled the above in a much simpler fashion. If it's a constant radius and you don't need to assign a graph function to it in any way (like needing ends normal to the plane or variable radii or pitch) you don't need to use an equation curve. In my model with the absolute accuracy set to .0001, the curve is accurate to .0000001 inch. The only drawback is Pro/E's usual inability to finish the regen cycle, so you must regen twice. If this is what you wanted, it's far less monkey business than the other method.
    Frank
    Oh, and I forgot to mention, making multiple turns is as simple as changing the section relation for the cylinder surface as follows for 2 turns:
    sd3 = rsd2/2
    For 3 turns, make that /3, etc.
    Have fun!
    Frank
    Anyone play with this yet?
    Hey Frank,
    I briefly looked at the 2nd model you sent me but I haven't had a chance
    to really dig into. We had to move on for the moment because the
    summary I posted actually did work for us. It may have not been ideal
    but we were able to clear the hurdle and keep the project moving. I
    really like the way you controlled the pitch of the helix, never seen
    that approach before. I will not share the file and destroy it as you
    requested once I am finished learning from it.
    I may post another summary after I tear into this again next week.
    Tracy Willis
    Designer / Drafter
    Cook Urological, Inc.
    11OO West Morgan Street
    Spencer, IN 47460
    (812) 829-4891
    (812) 829-1801 (fax)
    Confidentiality Note: The information contained in this e-mail is
    strictly confidential and privileged information which is intended for
    the use of the above addressee(s) only. All other use is strictly
    prohibited. If you are not the intended recipient, any review,
    distribution or copying of this document is strictly prohibited. If you
    have received this e-mail in error, please notify the sender immediately
    and delete the document from all computer systems, or notify Cook
    Urological at (812) 829-4891.
