Coord System calls
Pardon me for the simple questions that I should already know the answer to. Since I didn't set up this system, I don't know all the details. Unfortunately, I'm the only one around to run it now.
When I post a program, it enters a coordinate system with each tool that is called. Is there any way to eliminate this coord. system call? Since I replicate my programming for multiple stations, I need to edit the .tap file to change the coord. system anyway. It would just save me the hassle of 'search & replace'....
Also, is there an easy way to change the default coordinate system that is used?
Thanx
Tony
