Create a face gear
I have to model a face gear (frontal gear), but i don't know how. I need some help. Thanks. Luciano Giordano
    Liciano, What is a face gear? Mike
    A gear with tooth on the front in stead of on the side.
    If you know the sections, you can do a swept blend OR Variable Section Sweep to make one.. then pattern that and you get the full teeth. regards Joe. ---------------------------------------------- you can find some tips at... http://tipsfromjoe.blogspot.com ----------------------------------------------
