Feb 17, 2017 1:15 PM UTC
create curve with intersection of two surfaces..
Please share if any one knows
    Feb 17, 2017 1:18 PM UTC
    Select both surfaces holding control, then select intersect in the editing group of the model tab.  That will create a curve at the intersection of the two surfaces.
    jbhachu1-VisitorAuthor
    Feb 17, 2017 1:28 PM UTC
    Thanks Tyler, that's what I'm trying to do but the intersect command is greyed out
    Feb 17, 2017 1:32 PM UTC
    Once you have a surface selected the intersect command should not be greyed out.
