7-Bedrock
Feb 24, 2015 1:03 PM UTC
Creating a column in the UITree
Does any one have worked with creating a column in the UITree "ProUITreeColumnCreate". I could not find any sample in the installer path.
    Jul 31, 2017 12:24 PM UTC
    Hello @SRINIVASAN1
    You've done creating column in UI Tree?
    If yes, what is the Name of the attribute window in which column should be added?
