Aug 10, 2016 6:46 AM UTC
Creating a new template(.frm)
How to set the command for text font while creating a new template(.frm)
    Aug 10, 2016 2:45 PM UTC
    I believe the .dtl will set the defaults
    If you need some thing different, place the text.
    go back and select the text and then rmb and select text style
    modify accordingly
    ageorge-21-VisitorAuthor
    Oct 6, 2016 2:45 PM UTC
    Thanks Ron.
    Have one more doubt..
    Here we are creating a new .dtl file, in this how can we set the colors (rather making the System Color in Black and White)
    Oct 6, 2016 5:47 PM UTC
    create a .scl file (screen color??)
    easy enough to do
    File > Options
    in the options window, select System Colors
    in the config.pro, add:
    system_colors_file <filename>.scl
    I have several backgrounds: blue, black, white, and powerpoint
    I use mapkeys to activate the different files, for example, I like to work with blue but when I create a window clip .png, I will first change to a white background.  when I am done, I will change back to blue.
