Jun 25, 2012 3:06 PM UTC
Creo 1.0 locked up
When opening CREO 1.0 M040 everything seems to come up ok but it appears locked and does not respond to any commands. Can't find any open dialog boxes or anything to indicate that it is waiting for user input. It won't do anything no matter what button or menu I try to select. It is just locked up only option is to kill it via task manager. Worked fine on Friday!
    Jun 25, 2012 3:26 PM UTC
    maybe you need to be admin while installing it? Its possible that some part
    of it is requiring admin rights or admin to be the owner. I say run the
    set up as admin and see what happens
    > locked and does not respond to any commands. Can’t find any open dialog
    > boxes or anything to indicate that it is waiting for user input. It won’t
    > Friday!****
    Jun 25, 2012 3:28 PM UTC
    If this worked fine Friday I wouldn't think it's an install issue.
    Has the computer been rebooted since Friday? If not, please completely shut down, wait 30 seconds, then turn back on.
    Were any Windows Updates installed since Friday?
    Jun 25, 2012 6:10 PM UTC
    Do you have WindChill installed? If yes then look at the task bar and you may see the Windchill login blinking waiting for you to open it and accept it.
    David Brainsky
    Certified PTC Instructor
    Chula Vista, Ca. 91910
    Jun 26, 2012 10:02 AM UTC
    I have seen the same issue when linked to Windchill and having
    windows_browser_type mozilla_based_browser
    in your config.pro.
    If this is the case remove it from your config.pro to use IE per default or set it to ie_in_sep_process.
    This issue seems to have been solved in Creo 2.0 M010.
    /Bjarne
    Jun 26, 2012 10:38 AM UTC
    Creo 2.0 F000/F001 definitely has an issue with windows_browser_type set to mozilla_based_browser, but it is fixed in M010. We’ve had regular Wildfire 4.0/Creo 2.0 lockups ever since we switched from Intralink 3.4 to PDMLink 9.1/10.0.
    -Dave
    Jun 26, 2012 12:35 PM UTC
    We get a double login window with this option. Any ideas on how to fix that? Creo 2 M010
    Andy Hermanson
    Engineering Design Applications
    tel 605.275.1040 x51114 mobile 605.310.8168
    website www.daktronics.com
