It is something that PTC support should be able to help trace down.
That is why we pay for support.
If you are not getting satisfaction from the support technician, feel free to escalate the case to the next level.
If this is happening several times a day, I would suggest making this a #1 high priority case.
If you can capture a repeatable instance of when this happens, you can have a support technician monitor certain elements of the server interaction. Maybe it is as simple as figuring out the timeout cycle. Anything you do to make a case repeatable will help diagnose the problem much faster.
Even on my fixed license local machine, I had trouble with license timeouts or lost licenses when I put the computer to sleep. This was resolved with a registry tweak, and an older version of the license manager.
