Apr 24, 2013 8:55 AM UTC
Creo 2.0 M050 is available for download!
    Apr 24, 2013 8:58 AM UTC
    Download here: Order or Download Software Updates
    Apr 24, 2013 12:11 PM UTC
    We are currently going thru the WF5 to Creo 2.0 update class. IT loaded Creo 2.0 M040 for us to use. It has crashed 6 time in the last 45 minutes. I hope M050 fixes something.
    Apr 24, 2013 3:44 PM UTC
    Something is probably wrong with the platform or the install, Kevin. M040 has been relatively stable for the most part. By relative I mean I cannot duplicate a crash. If you can force a crash in a repeatable fashion, please report it to customer service.
    Thanks for the heads up, Rohit. Bit are flying
    Apr 26, 2013 3:35 AM UTC
    ur most welcome.
    i just want thwm to fix the save copy assembly window....
    Apr 24, 2013 6:30 PM UTC
    Is there much diference between m020 and the latest version is it worth updating?
    thanks mick
    Apr 24, 2013 6:35 PM UTC
    M030 fixed what was a major bug for us, the inability to edit specific config files through the options interface. I wouldn't consider using anything prior to M030.
    Apr 25, 2013 12:11 AM UTC
    M020 was more responsive to M030. I am not sure if this was fixed in M040. I don't yet know what to expect from M050.
    You can query the Update Advisor to see if your hot button issues were address in versions after M020:
    https://www.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
    If you cannot get to the site, talk to your administrator that can get access.
