Aug 3, 2012 1:57 PM UTC
Creo 2.0 or Creo Wildfire 5.0?
We are currently on Wildfire 3.0. Once we upgrade to Windchill 10.0 we wil also upgrade ProE. Does anyone have any thoughts on going to Creo 2.0 or Creo Wildfire 5.0.
Our biggest concern is that the GUI changes coming from Wildfire 3.0 to Creo 2.0 will be quite significant and that the users will have a tough time with the transition.
David
    Aug 3, 2012 2:17 PM UTC
    David,
    I've been using Creo Parametric 1.0 and now 2.0 from the moment they became available to me. I still have to go back and use WF3, 4, & 5 too. I hate that! The sooner all of our customers upgrade to Creo Paramtric 2.0, the better! From where I sit, the GUI learning curve is short.It doesn't take user's long to get the lay of the land locating their usual commands in the Ribbon Interface. There's a search tool for finding those that are not as apparent as others built into the GUI. The overall process flow improvements in CP2.0 reduce task completion time such that those benefitswill quickly overshadow the GUI learning curve! Go straight to CP2.0!
    I hope this helps!
    Have a GREAT day and upcoming weekend!
    Greg
    Greg Hamel
    Senior Consultant/Certified PTC Instructor
    Ve-U, a division of Visible Edge, Inc.
    38 Technology Way
    Millyard Technology Park
    Nashua, NH 03060-3245
    Phone: (603) 595-1422 x233
    ghamel@visible-edge.com
    http://www.Visible-Edge.com
    Aug 3, 2012 2:27 PM UTC
    AGREED
    We went straight to CREO2 and I would almost smack my foot with a sledge
    than use the legacy WF workstation.
    Users are up and running almost immediately - and the more they learn, the
    more they love this interface.
    Intralink 10.0 - even with all its implementation headaches is nice - right
    there in the imbedded browser I used to keep closed by default.
    Anthony
    Aug 3, 2012 2:32 PM UTC
    I have to echo other's comments. Move directly to Creo 2.0 and target the
    M030+ build if you can wait just a bit longer. You will hurt the user more
    with the WF5 interface (Design Modeling miss-match Detailing). I have been
    using Creo 1 and 2 since their release with the exception of customers using
    older versions and I hate going back now.
    Best wishes,
    Tim McLellan
    Mobius Innovation and Development, Inc.
    Aug 3, 2012 2:40 PM UTC
    We are on WF5 and as Tim says this is my biggest headache!
    Steve Fowler
    Senior Tool Designer
    Manufacturing Engineering
    Aug 3, 2012 2:54 PM UTC
    I don't have anything to add other than to agree (& a question for Tim
    below). Remember, WF5 has the ribbon in drawing mode, but it's poorly
    implemented and quite frustrating. Moving to WF5 will poison the well
    if you will against the ribbon interface which seems much better
    implemented in Creo2. We have two clients moving to Creo2 late this
    month and I'm looking forward to it.
    Tim - What's coming in M030 that's worth waiting until November? M020
    due Sept 2nd is supposed to have the config file issues fix I believe,
    although the SPRs
    Aug 3, 2012 3:09 PM UTC
    Doug et.al.,
    I meant to indicate Creo 2.0 M020. Approx. 200 bug fixes (however Creo 2.0
    M010 has been fairly stable for me).
    Tim McLellan
    Aug 6, 2012 11:41 AM UTC
    Great discussion. We're in a situation similar to David's.After going live with PDMLink 10 next month and users settling in with the newPLM toolI'm planning to go to Creo 2. When I gave a core group of CAD operators a sneak peak at Creo 2 in our last pilot group testiing of PDMLink, more than a few of them got a look of panic on their face - moreso than the first session outlining PDMLink. Great to hear from those using it that the learning curve isn't that bad.
    There are the usual complaints when a change like this comes around, but I think most admins are used to that. There were gripes about intent manager and model tree when they were added, now I don't think any of our users would want to imagine working without them. Forthose that are on Creo 2 Parametric, what would you say are the major benefits? Is it mostly the interface (after acclimating to it) or specific functionality improvements? Anything specific I can show our users in core functionality improvements would likely take the edge off the "who moved my cheese" reflex reaction to the interface.
    Erik
    Aug 6, 2012 1:33 PM UTC
    Hi Erik,
    Did you purchase the Flexible Modeling Extension? That is a really impressive improvement in the package! With FME, user's can easily edit previously created Creo or imported models (yes, even those IGES or STEP files that were previously known as "dump bricks"). Users can move geometry around in a Direct Modeling fashion without having to study the model tree and completely understand how the original features were built up to create the model. I've found, often - even on my own models that I created a month or less ago, it's faster for me to use FME to make changes to my model than it is to figure out how I built up the geometry and make traditional changes. Especially, last thing on Friday when thesupplier calls and needs a new file with a make-or-break change required to make the parts over the weekend to meet Monday's delivery requirement!
    Have a GREAT day!
    Greg
    Greg Hamel
    38 Technology Way
    dgraham-41-VisitorAuthor
    Aug 6, 2012 2:03 PM UTC
    Guys,
    Thanks a lot. I'm starting to lean toward Creo 2.0. Lot's of people seem
    to complain about the drawing mode GUI
    David Graham
    Windchill Administrator
    Pro|ENGINEER Administrator
    CAx Administrator
    Emhart Glass Manufacturing Inc.
    Emhart Glass Research Center
    123 Great Pond Drive | Windsor, CT 06095 | USA
    Telephone +1 (203) 376-3144 | Telefax +1 (860) 298 7397
    Mobile +1 (203) 376-3144 |
    Aug 7, 2012 2:11 PM UTC
    I agree with most everyone on this.
    Creo 2.0 is far better than WF5.
    We see improvements in the UI but the biggest advantage is the process of creating features and things we have always done. You have less clicks and everything is much faster and easier to do. The learning curve for my users was less than 1 week and I only gave them an 8 minute video to explain the major differences in the UI before installing it.
    As for Flexible Modeling. I see this as a potential disaster for many companies. The "Lazy" or "Wreckless" user can cause some sever problems using Flixbile Modeling and destroying the underlining parametric controls in a design. If any company is planing on using Flexible Modeling, they should first determine some very strict rules on when to use it and when not to use it. For imported geometry it's great, for removing features on an FEA model it's great, but allowing users to manipulate their designs with it can be a serious issue.
    Just some thoughts.
    "Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
