Jul 25, 2014 2:45 AM UTC
Creo 3.0 Pipe command missing?
i use Pipe command a lot. in Creo 2.0 it wasn't in a ribbon. and i added it by modifying in ribbon.
Creo 3.0, command is not there anymore. i tried searching it as well.
any Idea, where it moved to?
Jul 25, 2014 6:29 AM UTC
Try help:
1. Set the enable_obsoleted_features configuration option to yes to make the Pipe command available on the Commands Not in the Ribbon list.
2. Add the Pipe command to the desired user-defined group on the ribbon.
11-Garnet
Nov 24, 2014 6:52 AM UTC
Hi Radovan
But I try your method in the creo 3.0 m010, Pipe still can't work in my rbbon.
Nov 24, 2014 7:14 AM UTC
click Magnify Glass icon in the top right corner of Creo window. Then type pipe in text field in the top right corner of Creo window. Creo displays command names containing pipe string. Click Pipe command from displayed list.
Martin Hanak
Nov 25, 2014 1:02 PM UTC
Referring to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180185, to artivate some menus, need to set enable_obsoleted_features yes
