Jun 11, 2014 3:26 PM UTC
Creo Elements/Pro 5.0 (M160) - Notes insert: Enter in textbox
When I want to insert Notes with multi lines and I press enter key, the notes box closes. How can I enter multiply lines?
Thanks!
    bdegelingAnswer
    Jun 27, 2014 7:14 AM UTC
    Please create a new work folder which has write & read right and then:
    • Right click on Creo Elements/Pro or Creo shortcut icon and select pop-up menu option "Properties".
    • Switch to "Shortcut" tab in the "Properties" window.
    • Specify full absolute path to the required directory with in the "Start in" field.
    • Hit Apply and then Ok.
    Mahesh_Sharma
    22-Sapphire I
    Jun 11, 2014 4:52 PM UTC
    Bart,
    Do you have any application on your machine by the name as "Digital Guardian Agent"?
    bdegeling1-VisitorAuthor
    Jun 11, 2014 4:58 PM UTC
    Hello Mahesh,
    No such application present.
    Could it be related to an update of Microsoft? (One user has uninstalled KB2931365 and he was able to enter multiply lines)
    Mahesh_Sharma
    22-Sapphire I
    Jun 11, 2014 5:06 PM UTC
    Yes, it is possible due to Microsoft patch. In the past i have seen this issue due to external application "Digital Guardian Agent". You may try uninstalling patch KB2931365.
    bdegeling1-VisitorAuthorAnswer
