Dec 23, 2013 5:39 AM UTC
creo elements/pro 5.0 M200 refuses to show my language
I have
1. installed the language pack
2. changed the emvirmental variable (both LANG & PRO_LANG)
3. added "ENV=PRO_LANG=chs" to the end of the pro1.psf file
4. used command line like
set LANG=chinese_cn
"D:\Program Files\PTC\Creo Elements\Pro5.0\bin\proe.exe" "D:\Program Files\PTC\Creo Elements\Pro5.0\bin\proe1.psf" %*
5.modified the following options msg_translation' & "menu_translation
6. restarted the computer
7. or even restalled the application (the setup shows the correct language, though)
Unfortunately, nothing does the trick.
Any idea?
Thanks.
Dec 23, 2013 7:33 AM UTC
OK, but that only shows that you have this license available. I asked if you have configured Elements/Pro to actually run with this license, as shown (sorry, if this is a trivial question, but sometimes you can just miss something basic )
Dec 23, 2013 7:08 AM UTC
Have you also configured license to add Chinese_Translation to startup extensions? I actually never had to run Elements/Pro in Chinese, but I have seen there is this license option when you configure licenses, so maybe that's the problem?
Dec 23, 2013 7:27 AM UTC
Hi Lukasz,
Thank you for the quick reply.
Yes, the Chinese_Translation option is available in the the list from the ptcsetup.bat, as shown below.
Am I missing anything else?
