Jan 26, 2012 11:03 PM UTC
Creo Help Error: 500
Hello, Ive just installed Creo Elements 5.0 in my new laptop and I get an Http 500 error when I try to view the help file. Im using Windows 7. Ive seen the help file work fine in other installations so must be my configuration.
anyideas
HTTP ERROR: 500
INTERNAL_SERVER_ERROR
RequestURI=/index.jspx
Caused by:
java.lang.NullPointerException
followed by a long list of exceptions............
    Jan 27, 2012 8:49 PM UTC
    Hello!
    Try to contact with PTC's technical support ("Log a New Case"): http://www.ptc.com/appserver/cs/case/case_logger.jsp
    EwanP1-VisitorAuthor
    Feb 1, 2012 5:33 PM UTC
    Solved it Vladimir. It was a security setting in Windows 7.
    Feb 1, 2012 10:40 PM UTC
    Could you please share the solution? My team is also having this problem.
