Aug 4, 2015 3:19 PM UTC
Creo Laser Projection?
Need help/info on where to post or start. Need to find out if Creo has a module that will create Laser Projections for composite ply layouts. Any help is greatly appreciated.
Leo
    2-Explorer
    Aug 12, 2015 2:14 PM UTC
    Hello Leo,
    there is no specific module to drive a Laser Projector, unless it can make use of DMIS commands used for probe scanners (then it would be the module Pro/CMM to use).
    If you have software to output scan data in a point format (e.g. *.pts, *.ibl, etc...), then this point cloud can be read into Creo Parametric and the Restyle functionality will allow to handle them and create surfaces based on them - these surfaces could for example generate the outline for the plies.
    The flatten Surface functionality may be used to get a flat shape from the surfaces / 3D plies.
    Gunter
