Creo Parametric 1.0 Could not read .stl
- 2 replies
- 4236 views
- Translate All
I got some stl files from the software guys at my company. When I tried to open them in Creo they would not display in the file open window, even when I selected all files. I have been told that Creo will only display files it can open, which in my opinion is silly. When you select all files you should actually get to see all the files.
Anyway, I then used blender to open the .stl and it works fine. I exported it with blender as a new .stl with a different name and tried to use Creo to open that file. This time it does show it as an .stl file but when I open it I get the message 'Could not read STL file.' I tried exporting it as ascii as well, but no change.
Anyone have any ideas? The .stl format is pretty standardized I can not understand why a free program like blender can open the file and my powerful ProE program can't. Attached is one of the stl files.
Thanks for the help, and sorry for my frustration. I hate when simple things become complicated.
Josh
