Dec 1, 2016 7:52 AM UTC
Creo parametric 2.0 is unable to open specific dxf file
What are the possible listed reasons that Creo 2.0 is unable to open specific dxf file.
Regards
Sandeep
    bbrejcha
    bbrejchaAnswer
    Dec 6, 2016 5:10 PM UTC
    DXF can be many things.  Triangles, curves.....    Understand what is in the DXF.  If it does not come into the Sketch curve then the problem could be that there are no curves in the DXF model.  if your bringing the dxf into the part and it does not work then there could be something corrupt in the file.  you can try the DXF into a 30 day free licence of Rhino 3d and get a grip of what your importing or better yet watch the person export the DXF from the native package.   I suggest exporting the DXF in with various options so you can try multiple things.  (we at design engine do this in various classes to exude art work or logos in Creo)
    You can also make a copy of the DXF and load the file into wordpad or notepad to understand what is there.  notice the header will indicate what the native package is.   Consider taking our Creo Data Doctor class. its an intnese two days and well worth it.   http://proetools.com/prosurface-level-11-import-data-doctor/
    Bart Brejcha
    Design-engine.com
    Bart Brejecha designengine.com
    Dec 1, 2016 9:28 AM UTC
    Hi Sandeep,
    What happens when you try to open this drawing (if there are any error messages)?
    Dec 1, 2016 10:57 AM UTC
    Hi Vladimir
    Creo go to hang mode, no option other than kill the application
    Dec 1, 2016 12:18 PM UTC
    Can you attach this file to the message? Also try to open it with free Creo View Express: Creo View Express | PTC
    PetrP
    Dec 1, 2016 10:23 AM UTC
    Hey, for me in Creo drawing works to export DXF as "AutoCAD 2000 ASCII DXF" format.
    Also just try rename file to "1.DXF" or other simple filename (avoid complicated filename).
    Dec 1, 2016 10:58 AM UTC
    I changed name to 1.dxf but yet can't open file.
    PetrP
    Dec 1, 2016 11:08 AM UTC
    Try to get DXF in ASCII format as mentioned above if possible.
    Btw: sometimes it takes ages when Creo translating all entities/dimensions etc. so that is probably why screen frozen during import. Just let it work and don't kill the app. Take a nap and wait
    bbrejcha
    bbrejcha15-MoonstoneAnswer
    Bart Brejcha
    Design-engine.com
    Dec 8, 2016 4:44 AM UTC
    Thanks Bart Brejcha,
    This is very useful information you have shared
    Regards
    Sandeep
