Apr 17, 2015 12:25 PM UTC
Creo Relations
Is there is a way to password protect the relation that i define????
    TomU
    Apr 17, 2015 12:39 PM UTC
    Nope. The best you can do is hide them in a feature.
    2-Explorer
    Apr 21, 2015 10:19 AM UTC
    I would like to understand how to hide it.
    Regards
    Ketan
    Chris3
    Apr 21, 2015 10:58 AM UTC
    By hide it, Tom just means put it into a feature so it doesn't show up in the main relations. You could still see it by changing the "look in" from part to feature and picking the feature the relation was in.
    If you really wanted to you could also come up with a custom encoder and then decode a gibberish string to get you want you wanted. You could make it as complicated as you like. IE something like:
    string = "auioshfpiougrjbflkjskuvapyiuerhwlktjrbewgbfysdflgv"
    decode = extract(string,6,1) + extract(string,6,1)
    "decode" would then equal "hi"
    Note that if you do this in the main part relations it will turn "decode" into a parameter which will probably defeat the purpose as someone could just look at the parameter value.
