Feb 12, 2016 3:14 PM UTC
Creo that i dowloaded shuted down and they ask me to report an error code. Thus, how can i get help
Creo that i dowloaded shuted down and they ask me to report an error code. Thus, how can i get help.
18-Opal
Feb 12, 2016 3:48 PM UTC
Hi Cheikhna,
If you have maintenance, you can open a TS case here.
If not, please provide some detailed information as to what you did and what kind of error you ran into.
Amit
cismail1-VisitorAuthor
Feb 12, 2016 4:58 PM UTC
Hello Amit!
  For instance , i dowloaded the program and i finished all the process . After i got the Creo Parametric on my desktop, i wanted to use it but each time i went in the page told me :"Creo parametric is shutting down because it couldn't run the quality agent, which is required in this edition, report error 0*06000003.
        Thank You.
18-Opal
Feb 15, 2016 8:11 PM UTC
Please check out this thread for a solution to your issue: Creo 2.0 M200 Quality Agent Error
