Jul 25, 2014 4:06 PM UTC
Creo3 - Finite friction or ground springs?
Finite friction requires larage deformation analysis.
Ground springs require small deformation analysis.
... I can't have one if I have the other.
Is this correct?
    2-Explorer
    Aug 7, 2014 4:21 PM UTC
    Hi Charles,
    I can confirm!
    Found an internal SPR that states that finite friction requires LDA and another SPR confirms that all non-linear options (including LDA) are grayed out, when to-ground or advanced springs are used.
    Gunter
