Is it possible to eliminate or edit the value of the variable &xsec_name from cross section view labels? thanks
A
Anonymous
You can go to the view manager in the model view and rename the view, it will show up in the drawing with the corrected name (usually 'A') You can also right click the arrows in the drawing and click "rename" and the view will be updated. Or, you can right click the label and select erase
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
