Custom cycle syntax
I have made a few custom cycles based off of the example in the help area of ptc. I want to do basically the same hole making sequence that they are doing in the example but I will have more the on reference point to change feed. I believe that I have the reference and variables correct but am unsure of the expressions as well as the cycle syntax. Does someone have more info on custom cycles so I can better understand them?
