Decimal places being output in Customize
Hi again,
If you use an &string to fill in a value in the customize dialog box, the value comes out with 6 decimal places. Ie. if I use &pocket_number for the tool number, I get 131.000000. How do I remove/control the decimal places?
Jeff Voegele
Solar Turbines
    3-Newcomer
    Hi Jeff,
    When using parameters in tables you add in square brackets the decimal and the number of places you want.
    &mfg.oper.workcell.head.tooltbl.cutter_diam[.2]
    Cheers,
    Dino
    >>> <-> 7/7/2005 3:09 PM >>>
    Hi again,
    Jeff Voegele
    Solar Turbines
