Default Text Size
How do you set the default text size to be .19 at all times?
    you have to set it in the drawing setup file usually.
    Your config.pro should have pro_dtl_setup_dir and enter a location as your value like $PROSTDS\dtl it should also have a drawing_setup_file like $PROSTDS\dtl\config.dtl, make sure that you change the drawing_text_height in your config.dtl
