Nov 16, 2012 8:35 PM UTC
Degree symbol in the hole chart
I am creating our ownhole chartfile. Is it possible to get the degree symbol shown or will I have to use DEG?
Steve G
    STEVEG21-Topaz IAuthor
    Nov 16, 2012 9:14 PM UTC
    Thank yous go to Ron. He gave me the hint.
    I knew the code was ALT+0176 so I typed the letters ALT then the plus sign then 0176. I never though actually pressing the ALT key then 0176 would put the symbolin Notepad.
    Steve Galayda
    Nov 16, 2012 9:46 PM UTC
    When I created the degree symbol in a note the ASCII codes saved were
    <soh>$<stx>
    I wonder if you could enter these codes through the keyboard:
    <ctrl>A $ <ctrl>B
    I tested this in a note and if you enter <ctrl>A $ you get a degree
    symbol. See if that works.
    Or enter it (copy / paste it from a pro-e note) like this: {0:$[1]}
    Christopher F. Gosnell
    FPD Company
    124 Hidden Valley Road
    McMurray, PA 15317
    Nov 16, 2012 9:56 PM UTC
    I could not get it to work with your suggestions. I also tried <ctrl-a>$<ctrl-b> In other examples they had the 'a' and 'b' inside the brackets.
    Steve G
    Nov 16, 2012 10:07 PM UTC
    you should just hit cntrl & a (hold control press a) type your letters or
    characters then cntrl & b to end it
    x = a depth symbol, n = diameter, the other letters give you various gd&t
    symbols, I've never tried the numbers and other characters, but it should
    work
    here's a pretty good alt symbol list for those who need it
    Nov 19, 2012 2:33 PM UTC
    I thought I tried <ctrl-a>$<ctrl-b> before and it didn't work. Maybe I typed a wrong character. Walt sent what he has in his .hol file and I tried it again and this time it worked. He also said there is a document that PTC has listing all the symbols. Here they are. TPI 104111.
    The only thing is the TPI was last updated Oct 2000 but it should still be good.
    Description
