Oct 17, 2013 9:02 AM UTC
Degrees of freedom in Gimbal connection
How many degrees of freedom do we have in Creo Gimbal connection?
What is the difference between Gimbal and Ball connection?
    Oct 17, 2013 9:53 AM UTC
    Both have 3 dofs
    Ball is centred using a point or vertex
    Gimbal is centred by using co-ordinate systems
    You cannot control the rotations of a ball
    You have 3 servo controllable/measureable rotational dofs in a gimbal
    The manner in which the gimbal rotational dofs are driven in a matters as 'gimbal lock' can occur.
    CHAGS1-VisitorAuthor
    Oct 17, 2013 10:10 AM UTC
    Thank you, Charles...
    I am simulating the mechanism of ackermann steering. Can I use the Gimbal connection for constraining tierod ends? Right now I have constrained both the ends of the tierod using ball connection with a cone opening angle of 60 degree(which is assumed).
    Oct 17, 2013 3:05 PM UTC
    Yes you can. Though I don't think it's possible to limit the connection axes to your 60deg
