Aug 21, 2013 5:35 AM UTC
difference between the two shrinkage formula's?
could some one please expalin the difference between the two different shrinkage formula's in Pro/Engineer.
(1+S) and 1/(1-S)?
    Aug 30, 2013 7:25 AM UTC
    • 1+S — Uses a precalculated shrinkage factor that is based on the original geometry of the reference model.
    • 1/(1–S) — Enables you to specify a shrinkage factor that is based upon the final geometry of the reference model once shrinkage is applied.
    Aug 31, 2013 6:46 AM UTC
    hey sumeet..how are you?....
    i am not that wise dude.....i read that...did not understand...the second one and then read the first one again...and now i am confused..it would help if you could elaborate with a example.
    thanks.
    Sep 1, 2013 6:23 AM UTC
    S is in percentage when you scale the whole model so 1+s s=10% s,viz 0.1 1+0.1=>1.1 x model size
    1+s will enlarge the model size apply shrinkage already and 1/1-s will reduce the model size ( assuming s is positive in both cases)
