Jan 16, 2014 1:18 AM UTC
Direct calculation of a volume
Is there now in Creo 2, a simple way to calculate the internal volume of a shape, without going through the Shopsystems brush marks as described in the knowledge base.
Cordially.
Denis
    Jan 16, 2014 1:55 AM UTC
    I use a merge process to figure this out. I don't know of a direct method.
    Jan 16, 2014 9:28 AM UTC
    Antonius,
    could you possibly elaborate?
    John
    Jan 16, 2014 4:44 PM UTC
    John, I assemble a block (part) and the object I need the volume from. I then use the Merge feature (from one of several locations) to remove the part from the block. Then, in the block part file, trim away any exterior volume and I have the remaining volume.
    Jan 16, 2014 9:14 AM UTC
    Since WF5 you can also measure the volume of closed quilts.
    Perhaps a surface copy would do the job?
    Jan 16, 2014 4:48 PM UTC
    I did not know this. What is the process in Creo exactly?
    Jan 17, 2014 4:19 AM UTC
    You can also use analysis features, if you have the capability, to get the volumes.
