Jun 4, 2015 1:28 PM UTC
Direct Modelling and Parametric Modelling
Hello Creo genius
I hope this is an easy question for you.
If my R&D team create a model (for a new innovative product) in Direct Modelling and then once the concept is finished, I want my designer to create multiple variant and maybe having this new product configurable. Can I convert this model created in Direct Modelling into a Parametric Model ?
If so, how easy is it ?
if not,  does that mean I must start with Parameter modelling and since I do not know from the upfront if a new product will have variant or not, then to avoid the risk of not being able to convert, my R&D Team will always use Parametric Modelling even if at that stage it is not as efficient.
Best regards
