Mar 4, 2011 10:58 AM UTC
Display of a variable and the value corresponding to it
As it is possible to display in a graphic window (in a mode 3D) the following information: the geometrical values together with parametres corresponding to them. For example: d1 = 500 mm?
    VladimirN24-Ruby IVAuthor
    Apr 15, 2011 10:23 AM UTC
    The answer to this point in question can be found here:
    http://communities.ptc.com/blogs/vpalffy/2011/02/28/create-driving-dimension
