Nov 12, 2014 8:10 AM UTC
DRAFT OVER 30°
hello,
is it possible to have a draft over 30° vith the command DRAFT?
thanks
    Nov 12, 2014 10:49 AM UTC
    In Creo 3 it goes up to 89.9°.
    Nov 12, 2014 11:24 AM UTC
    Yes; you'll want to upgrade to Creo 3 M010. It didn't appear that draft over 30 worked with the initial 3.0 release.
    Nov 13, 2014 2:55 PM UTC
    .... and if you can't eject the part from the mold at 89.9 degrees, then there's something wrong with your part design
    Patriot_1776
    Nov 13, 2014 3:25 PM UTC
    Bwahahaha! I remember when the draft stopped at, what, 7 degrees? Which is still WAY more than you should ever need. It's handy that it's more robust now, so you can cheat on certain geometry. I remember draft not working and having to instead sweep angled surfaces to use as cuts.
