DXF output
We are running WF 3.0 M130, and we are outputting .dxf's that are then
converted using TruTops to a .geo. After this conversation takes place
all the solid lines are dashed. If we take and open the .dxf in AutoCAD
and resave it as either a 2000 or 2004 .dxf the file then converts
correctly. Has anyone encountered this or able to tell me what is set
incorrectly. I would greatly appreciate it.
Tyler Nielsen
tnielse@daktronics.com
Mobile- 605.690.1156
Desk - 605.692.0200 ext. 56572
Daktronics, Inc.
    6-Contributor
    We have seen this before with some colors. What we typically do now is open the dxf in TruTops and modify the color to white to avoid problems. If I am remembering correctly, we had a problem with lines colored cyan. TruTops turned all cyan lines into dashed lines.
    Hope this helps
    Doug Purtill
    There's a setting to have Pro|E output an ACAD 2000 style DXF. Set
    dxf_export_format to 2000. It's supposed to be the default, actually,
    in WF3, but if using the options dialog, it defaults to 12 regardless of
    the option setting.
    There are a variety of DXF options you can set that may help, search for
    'DXF' in the options dialog.
    Doug Schaefer
