Oct 8, 2011 3:19 AM UTC
Edit a mapkey
Is there a method to edit a mapkey? I'm working on a rather long mapkey and if I miss-type a line, can I go back and change it? Tools...Mapkey...Modify seems to only let me start over from the beginning? Thanks
    Oct 8, 2011 5:01 AM UTC
    Hi
    If your mapkey is too long why don't you try for nested mapkey ?
    Regards
    K.Mahanta
    Oct 10, 2011 6:44 AM UTC
    Tony,
    if you want to change manually entered text, you can save your mapkey into config.pro file and modify mapkey by editing config.pro using notepad.
    Martin Hanak
