Edit Definition
Hello, I am not able to edit the placement of the sketch. No dialog box opens when you select "edit" of the internal sketch, directly goes to the sketcher for editing the sketch. This happens for sketch curves also.
    When you are in Sketcher select Sketch>Sketch Setup. There is also an icon you can put on the sketcher toolbar for Sketch Setup.
    Thank you very much.
