Aug 26, 2014 7:04 PM UTC
Edit Symbol
Okay, haven't had the need for a very long time to edit a symbol from our symbol library and don't remember ever doing it in CREO 2. I tried to search help, but cannot come up with the how and to save it back. Is there something simple that I am missing?
Thank you,
Brian Toussaint
Systems Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
Phone: (770) 487-2331 ext. 1216
Fax: (770) 487-3359
www.hoshizaki.com
    Aug 26, 2014 7:43 PM UTC
    When you're finished editing, the 'write' menu pick will allow you to write to the symbol folder (likely the folder set in your config.pro).
    It's in the first menu after you pick 'Symbol Gallery' to do your editing.
    [cid:image001.png@01CFC144.6BD40E30]
    Aug 26, 2014 7:56 PM UTC
    You also need to make sure that when you write the symbol back that you set
    the directory.
    Aug 26, 2014 7:59 PM UTC
    Good point. If you have a single custom symbol directory, as we do, it will default to that. If you have a folder structure, be sure to pick the right one. (Of course you can move it afterward if a mistake was made.)
    Aug 27, 2014 4:18 PM UTC
    Thank you for showing me how to get to the symbols to edit them.
    Next question I have is, can you change the color of a symbol when you are editing it?
    Thank you,
    Brian Toussaint
    Aug 27, 2014 4:20 PM UTC
    Yes, you can. Edit the symbol through the Symbol Gallery. Then choose the
    geometry that you want to do a color change on and modify the color.
    Michael P. Locascio
