egg shaped circles
Just loaded up the Cocreate PE version and have noticed that all circles are ellipse shaped. Squares are also off by the same ratio. Any suggestions on how to correct this.
    This should be settings in the graphics card driver.
    I have the resolution set to 1280 by 1024. I have reduced this setting and it made no difference. When I had access to a Cocreate license I had ran this on this computer and I had no problems until I loaded the PE version. If you could let me know what else I can try changing on my graphics card I would appreciate it.
    This depends on the graphics card. Is it a wide screen monitor? so it could be better to set the display to 1920x1024 In my driver settings I have the option: 1280x1024 fix scaling ratio and this works fine. WoHo
