Jan 4, 2013 6:27 PM UTC
Email server
All -
Our IT department recently did 'maintenance' on our email server which turned out to be more 'replacing' than 'maintenance'... Now my users are not receiving their workflow-generated emails. Can someone please tell me where the email server is identified so I can get it pointed in the right direction again? (PDMLink 9.1 M050).
Thanks in advance!
Chrystal Johnstone
Red Dot Corporation
    Jan 4, 2013 6:30 PM UTC
    Please check <wt_home>/site.xonf and check below property
    <property name="wt.mail.mailhost" overridable="true" targetfile="codebase/wt.properties"&lt;br"/> value="<mail server=">"/>
    and replace value <mail server="> with right mail server
    regards
    Venkata Kotra║Sr.Analyst, Engg Systems ║IS, HHI
    [cid:image001.gif@01CDEA5E.26C65550]
    Jan 4, 2013 7:02 PM UTC
    Use xconfmanager to check values in the property files.
    Xconfmanager -d wt.mail.mailhost
    Will return the current value.
    Xconfmanager -s wt.mail.mailhost=<new mail=" server="> -p
    Will set and propgate the new value of <new mail=" server="> to windchill
    Thank you,
    Ben H. Loosli
    USEC, INC.
    Jan 4, 2013 7:17 PM UTC
    Thanks!
