Oct 18, 2012 10:33 AM UTC
ESD Symbol (Triangle with struck trough hand)
does anyone know where I can get an ESD symbol (Triangle with struck trough hand) from.
Or do I have to create it myself.
Here's a picture of it
Best Regards
Jens Wagner
    J.Wagner12-AmethystAuthor
    Oct 18, 2012 12:04 PM UTC
    my request was too urgent 🙂
    I created one by myself.
    For those who need it, it's attached.
    Thanks anyway.
    Oct 22, 2012 1:36 AM UTC
    Sorry, but yes, these have to be created unless you are lucky enough to find a vector file that can be imported.
    The idea that you can underlay an image is helpful. And you can also consider using the image as a texture (Decal).
    The only tip I can give you in creating symbols is to avoid filled polygons (solid hatch). I have had a lot of trouble with graphic errors. Trimmed offset lines representing close hatching is the best way to create a solid field. Have a close look at some of the supplied symbols and you will see this.
    Oct 24, 2012 5:38 AM UTC
    Hello Antonius,
    thanks for that hint. I will keep it in mind.
    Best Regards
    Jens Wagner
