Expert Framework
Hello, In the system information it says that the Expert_Framework option is installed, but I don't find the menu in Pro/E Wildfire 4... Do I have to set some options? thanks, bern
    Expert Framework is a third party application runs in Pro/E. http://www.buw-soft.com/content/en/produkte/exp_framework_ext.php?p=Mw==&s=Mw==
    Thanks Aris. bern
    Bernard, EFX only shows up in your menus in an assembly. In part mode or drawing the menu does not appear. Before using it, you must set a project and create an assembly sketch to place steel profiles onto.
