Jun 21, 2011 2:09 PM UTC
Extended Exit Logger?
Anyone have any documentation or information about the Extended Exit Logger for Creo or Pro/E? I have searched the PTC.com web site and can only find https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS7633 which is a case solution. There seems to be no documentation or info anywhere. I need to learn more about this tool.
Mike
    mbraaten10-MarbleAuthor
    May 11, 2012 6:43 PM UTC
    Hello???
    May 11, 2012 6:47 PM UTC
    Tech Support will have to supply you the exit logger. Open a case and tell them you want it.
    May 11, 2012 6:51 PM UTC
    Thanks. I'll give that a try.
