Extensions
I have a Pro-e file with the extension .crc.
Any one know what the extension .crc is?
Robert Parsons
Designer
Gilbarco Veeder-Root
7300 Friendly Ave.
Greensboro, NC. 27409
Phone 336-547-5604
This message (including any attachments) contains confidential
and/or proprietary information intended only for the addressee.
Any unauthorized disclosure, copying, distribution or reliance on
the contents of this information is strictly prohibited and may
constitute a violation of law. If you are not the intended
recipient, please notify the sender immediately by responding to
this e-mail, and delete the message from your system. If you
have any questions about this e-mail please notify the sender
immediately.
    robert511-VisitorAuthor
    Wow! What a fire storm!
    I've been inundated with information about circular references which is
    what I have.
    I was able to open the .crc file and found the circular ref is only
    three features deep (Whew).
    I'm not sure if this is what is causing my problem though.
    I have a Zip file with all the files that make up the assembly, I guess
    I should mention I did not create this
    assembly, It was sent to me from another of our company sites, and I'm
    not sure where they got it from maybe a vendor.
    When I try and import the files into a workspace I can get most of the
    files except the assembly file that has the same name
    as the circular ref file. The circular ref file refers to a sub assy
    file which has a O-ring that is the problem I bet they used
    the surrounding geometry to set the boundaries of there O-ring.
    Could this circular cause the assembly from importing to a workspace?
    Robert Parsons
    Designer
    7300 Friendly Ave.
    Phone 336-547-5604
    immediately.
