Nov 10, 2013 1:56 AM UTC
Extracting Zip file download University Creo 1.0
Hi, I have downloaded the zip file of the University edition of Creo 1.0 and copied the file to a DVD from work since the workplace has a faster line. I then tried to extract the file from my home computer and i got the following message "The compressed (zipped) folder is invalid or corrupt". I then dowloaded the file to my home computer and after waiting until the download was complete I attempted to extract the files and got the same message.
I am trying to submit my course work created in WF5 into Creo 1.0 that the instrutor requires to be submitted in.
Anyone have any solutions as to why I am unable to extract the downloaded zip file from PTC?
Best regards,
Ricard
Nov 10, 2013 10:44 AM UTC
You can request PTC's "Academic Support" here: http://www.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
Nov 10, 2013 7:40 PM UTC
Are you sure you have sufficient disk space for the extraction process? If I recall correctly, you need 3X the space... one for the original, one for the temp folder, and one for the destination.
Nov 10, 2013 11:47 PM UTC
Hi, Thanks for responding. Got plenty of disk. Not even getting to the point of extracting files where one would get an error regarding insufficient space.
Best regards,
Ricardo
Nov 10, 2013 11:53 PM UTC
Then I might suggest that the file is indeed corrupt on PTC's end.
If you cannot get to the link Vladimir posted, you might consider sending a community message toTimothy Brotherhood so he can investigate.
I'm assuming academic and university version are the same or similar.
