Extruding to an angled face problem
- 4 replies
- 4262 views
- Translate All
Here is a problem I am sure someone will find easy to solve. I have a student trying to extrude sketch 2 (The red shape in the attached JBG file) from its current location to the angled face to its right. However, the shape of sketch 2 needs to follow the angle at the end of the object and stop 3 mm short of the angled face. Ideas? Thanks in advance BTW, i tried to attach the pro-e file (called angled_extrude.prt.1) and because of the .1 it will not attach. It is considered as not being one of the excepted extensions. However, everytime you save pro-e adds the number. Isthere a solution to this? Last tiem I emailed the file to one of the members.
