Failed assy connection
WF3, M170
I have 2 components that assemble via a pivot pin.  I can assemble them together using an align on the pivot axes and mating the RIGHT planes.  Assembles fine, with or without an orient constraint.
However, when I try to convert to connections so I can apply limits to the pivot, it fails to connect using the same references.  I cannot figure out why.
If I use the assy constraints and uncheck the 'allow assumptions' box, even though it generates no errors, it still will not move if I attempt to drag it.  During the assy I can hold ALT-Ctrl and drag it just fine, but not once it's assembled.
Any idea how I can figure out what's wrong here?
Doug Schaefer
    An update based on responses so far:
    - All refs chosen are from only the two components.
    - Specifying rotation refs or not doesn't help.
    Someone suggested selecting surfs instead of datum planes, I'll try that
    in the AM.
    Doug Schaefer
