FEMPost & ANSYS
Ok, I know I'm asking a lot of questions about this, but I value this
group's experience & input.
Do any of you have experience using Mechanica's FEMPost functionality to
examine results from ANSYS?
Please tell me strengths, weaknesses, etc.
We're on WF2, if it makes a difference....
Lyle Beidler
Knoll, Inc. Product Development Mechanical Designer
Phone: (215) 679-1205 Fax: (215) 679-4491 lbeidler@knoll.com
Pennsylvanian by birth, Nittany Lion by the grace of God
    Lyle,
    I have used this interface briefly and it worked fine for me, however;
    -As Yuri pointed out; material properties, boundary and initial
    conditions are all limited to linear capabilities in Pro/M
    -Post processing quantities are also limited to those defined in
    Pro/FEM. While running directly in ANSYS gives you a slightly extra edge
    in what quantities you can view. For example stress/strain along a
    certain path/edge.
    -Post processing results in Pro/FEM is easier for viewing than in ANSYS,
    but I used to use ANSYS 6.0 and may be newer versions are different.
    Hope this helps,
    Salman
    > to examine results from ANSYS?
    > Thanks
