May 28, 2013 5:49 PM UTC
File syntax or length restrictions
Are there any file syntax restrictions in Creo2?
Are there any File lenght restrictions in Creo2
Are there any file depth restrictions in Creo2? In other words can you put files many layers deep or is that a problem?
    May 29, 2013 6:38 AM UTC
    Gerald,
    >>> in file names you can use letters (a-z), digits (0-9), underscore and hyphen
    >>> max length of filename is 32
    >>> max length of directory path is 256 (?)
    Martin Hanak
    Gerald,
    Martin Hanak
    GRS1-VisitorAuthor
    May 29, 2013 12:33 PM UTC
    Thanks for your help on this!
    Gerald
    May 29, 2013 8:14 PM UTC
    You can used modelcheck
